Normal Topic Creating image from diagram (Read 3202 times)
PiotrMakowiec
May 29th, 2018 at 5:49pm
Hi everyone Smiley
I've got a problem during creating image from diagram.
Shapes inside diagram are sliced and deformated.
The funny thing is, that the same code on my computer works properly (Windows 10, VS 2017 Community, Version of MindFusion: 3.5.3) - image is good
But the same code on other computer (Windows 7, VS 2017 Professional, Version of MindFusion: 3.5.3) - here images are crashed.
Here is the link to the repo, if someone has time, can check:
https://bitbucket.org/pieterm4/mindfusion-export-thumbnail/src/master/
Good picture and wrong picture are in the attachments.
If someone has any idea what is happening, I will be very thankfull Cheesy
Thanks for your help Smiley
Online
Re: Creating image from diagram
Reply #1 - May 30th, 2018 at 6:50am
Is it better if you call diagram.UpdateLayout before exporting?
PiotrMakowiec
Reply #2 - May 30th, 2018 at 7:09am
Unfortunately it didn't help Sad
Thanks for responding
Below is result of saving diagram.
PiotrMakowiec
Reply #3 - May 30th, 2018 at 7:17am
And it's only happening on the computer with windows 7.
On other with Windows 10 work's properly... ehhhh Sad
Online
Reply #4 - May 30th, 2018 at 12:07pm
We couldn't reproduce. On what .NET version are you running the code?
PiotrMakowiec
Reply #5 - May 30th, 2018 at 12:52pm
I was testing it on .NET 4.6.1 and 4.7.1 on Windows 7.
Online
Reply #6 - May 31st, 2018 at 2:39pm
Could you check if this build improves anything -
https://mindfusion.eu/_beta/create_image_test.zip
