Normal Topic Text at the Diagram Link in the middle (Read 3609 times)
Kuzya
Jun 7th, 2018 at 3:37pm
Hi Lyubo,
I want the text to be placed exactly in the middle of the diagram link.
I use the method:
link.setTextStyle(LinkTextStyle.OverLongestSegment);
link.setTextAlignment(Alignment.Center);
but have I not achieved the desired result.
Kuzya
Lyubo
MindFusion team
Re: Text at the Diagram Link in the middle
Reply #1 - Jun 11th, 2018 at 5:22am
Try with:
Code (Javascript)
link.addLabel("This is my text");
Lyubo
Kuzya
Reply #2 - Jun 15th, 2018 at 8:33am
Hi Lyubo,
it didn't help  Undecided
i need -> Bild1
i have -> Bild2
Kuzya
Lyubo
MindFusion team
Reply #3 - Jun 18th, 2018 at 5:12am
The DiagramLink.addLabel method returns an instance of the LinkLabel class that is used to represent the text (the label can also be accessed via the DiagramLink.labels collection). You can specify its general alignment with the setHorizontalAlign and setVerticalAlign property setters, and fine tune its position via the setLinkLengthPosition, setSegmentPosition or setControlPointPosition methods. Check if you aren't setting one of these properties already in your code, so that they affect the labels' positions.
Lyubo
Kuzya
Reply #4 - Jun 18th, 2018 at 5:07pm
we're a little bit confused.
We would like to use the native texts of the edges. We like the possibility to position the texts over the longest segment. This does not seem to be possible with the labels.
Our only problem is that when we use the native text of the edges, they are not vertically centered on a horizontal edge. Compare Figures 1 and 2 above.
Unfortunately, we don't seem to be able to influence the native texts of the edges as finely as the labels, do we?
For us it looks like an error in the program that the text on the edges is moved so strangely, because if the text is aligned right or left to the box, then it is centered vertically correctly.
Kuzya
bild_1  javaScript
bild_2 -Windows Forms
Lyubo
MindFusion team
Reply #5 - Jun 19th, 2018 at 1:40pm
It really appears that the text bounding box is positioned in reference to its top-left corner right now. Try if the build from this archive works better for you: https://mindfusion.eu/_beta/jsdiag_linktext.zip.
Lyubo
Kuzya
Reply #6 - Jun 28th, 2018 at 12:48pm
Hi Lyubo,
thank you so much  it helped us. Smiley
there is the possibility to center the text inside the edge
i need -> Bild1
i have -> Bild2
Kuzya
Lyubo
MindFusion team
Reply #7 - Jun 28th, 2018 at 2:05pm
Unfortunately this is not possible with the current build. We'll try to add this for the next release.
Lyubo
Kuzya
Reply #8 - Jun 28th, 2018 at 2:10pm
Hi Lyubo,
When will the next version be released?
Lyubo
Reply #9 - Jul 31st, 2018 at 12:58pm
New build here should let you center text by calling link.setTextAlignment(Alignment.Center) -
https://mindfusion.eu/_beta/jsdiag322.zip
We'll be releasing it in a couple of weeks.
