Normal Topic Setting color for the anchor points of a link (Read 2755 times)
ashar11
Jun 9th, 2018 at 5:47am
    I have two existing nodes connected by a link, how can i change the color of anchor points of that link on both origin and destination.
Re: Setting color for the anchor points of a link
Reply #1 - Jun 11th, 2018 at 8:34am
There's AnchorPoint.Brush property, but make sure you are not using a shared AnchorPattern instance if you need to change colors dynamically.
ashar11
Reply #2 - Jun 11th, 2018 at 10:12am
AnchorPoint.Brush didn't worked out for me. Is it possible to set the link brush for existing links like given in the code below. If i apply link brush in LinkCreated function it show me the brush , but not for existing links.
   int countLinkColour = fc.diagram.Links.Count;
            for (int jj = 0; jj <= countLinkColour-1; jj++)
                if (fc.diagram.Links[jj].ToolTip != null)
                   fc.diagram.Links[jj].Brush = new SolidColorBrush(Colors.Yellow);
Reply #3 - Jun 12th, 2018 at 7:59am
It should be possible for existing links too. Trace that code with debugger to see if it ever gets to the fc.diagram.Links[jj].Brush = ... assignment.
ashar11
Reply #4 - Jun 12th, 2018 at 9:18am
Yes when debugging its going there , and even stroke is working too but not the brush. I also cannot see the brush(the square shape existing at the end of wire) it only gets visible when i create the link first time, after reopening the application there is just a wire. The picture is attached below in which brush from first link got disappeared after reopening the application
fc.diagram.Links[jj].Brush = new SolidColorBrush(Colors.Yellow); (Not working )
fc.diagram.Links[jj].Stroke = new SolidColorBrush(Colors.DarkBlue); (Working, it changes the color of existing link)
Reply #5 - Jun 13th, 2018 at 7:22am
Is that square shape a Shape instance you assign to HeadShape and BaseShape properties? If it's a custom shape with your own ID, make sure you register it from application's startup code before loading any files.
ashar11
Reply #6 - Jun 13th, 2018 at 9:14am
Thanks now its working, yes that was a shape instance present in linkcreating which i forgot and i was assuming that it got visible from the linkcreated event after applying brush to yellow.
