Normal Topic Evolving Item Tooltip (Read 4218 times)
fractal07
Jun 15th, 2018 at 5:46pm
Still working hard on project based on your (really good) scheduler, customers asked me to evolve the tooltip display.
I already use a custom version, using different formats, but is there a way to change the display? I mean, how can I change the font (size, font, colors...) and improve the Tooltip display?
Thank you for your support,
Kind regards
Olivier
Re: Evolving Item Tooltip
Reply #1 - Jun 18th, 2018 at 7:33am
You can get a reference to the underlying .NET ToolTip control using Calendar.ToolTip property -
https://www.mindfusion.eu/onlinehelp/planner/index.htm?P_MindFusion_Scheduling_W...
and then use the ToolTip class API to customize it.
fractal07
Reply #2 - Jun 28th, 2018 at 5:28pm
Hello Slavhco,
Thank you for your support! It works fine
