Normal Topic Destination node in the linkCreating event (Read 1725 times)
Kuzya
Jun 28th, 2018 at 12:32pm
Hi Lyubo,
Is there a way to get to the destination node in the linkCreating event? At the moment it always seems to be a dummy object. In the Created event I get to the destination node, which is unfortunately too late.
Kuzya
Lyubo
MindFusion team
Re: Destination node in the linkCreating event
Reply #1 - Jun 28th, 2018 at 12:48pm
Try this:
Code (Javascript)
function onLinkCreating (sender, args)
    var link = args.getLink();
    if (!link.targetConnection)
        return;
    // the destination node
    var destination = link.targetConnection.node;
Lyubo
Kuzya
Reply #2 - Jun 28th, 2018 at 12:53pm
Hi Lyubo,
thank you very much for your help
it works  Cheesy
Kuzya
