Normal Topic Tooltip is not displayed. (Read 3134 times)
Kuzya
Jun 29th, 2018 at 7:38am
Hi Lyubo,
we set tooltip with the method SetTooltip ().
Tooltip is set but not displayed.
Could you please help us and tell us what could be the cause?
Thank you very much.
Kuzya
Lyubo
MindFusion team
Re: Tooltip is not displayed.
Reply #1 - Jun 29th, 2018 at 11:38am
The digaramItem.setTooltip method works as expected in my test. The tooltip is set and displayed on cursor hover. Are you seeing any errors in the browser's console window?
Lyubo
Kuzya
Reply #2 - Jul 3rd, 2018 at 12:59pm
No error message is displayed. Shocked
Is there any propoty in Diagram that is responsible for displaying tooltips ?
Kuzya
Lyubo
MindFusion team
Reply #3 - Jul 3rd, 2018 at 1:51pm
We have such property on other platforms, but not in jsdiagram. We identified a bug in the code setting the tooltip delay timer. Try if explicitly setting the delay will resolve the issue for you:
Code (Javascript)
diagram.setTooltipDelay(500);
In addition to that, you can try overriding the Diagram.onTooltip function and check if it's really called on mouse over in your case:
Code (Javascript)
var onTooltipOriginal = MindFusion.Diagramming.Diagram.prototype.onTooltip;
MindFusion.Diagramming.Diagram.prototype.onTooltip = function ()
    onTooltipOriginal.apply(this);
    console.log('onTooltip called');
Lyubo
Kuzya
Reply #4 - Jul 5th, 2018 at 6:55am
i can't use the program part because i get the error message : 'Property "onTooltip" does not exist on type "Diagram" '
Kuzya
Lyubo
MindFusion team
Reply #5 - Jul 5th, 2018 at 8:53am
What version of the control are you using? Tootlips support was added back in v.1.5, and the tooltipDelay property was added in v.2.5.
Lyubo
Kuzya
Reply #6 - Jul 5th, 2018 at 12:54pm
MindFusion.Diagramming for JavaScript and HTML5 Canvas
version 3.2 (Demo)
Kuzya
Lyubo
MindFusion team
Reply #7 - Jul 5th, 2018 at 2:17pm
Are you sure there is no cached older version that your browser is using? Does it work in another browser? If it doesn't still, can you send us a small sample that reproduces the no-tooltip issue, so we can investigate? You can mail it to support@mindfusion.eu.
Lyubo
Kuzya
Reply #8 - Jul 9th, 2018 at 1:43pm
Thank you for your help.
I found the error.
error due to zIndex
Kuzya
