Normal Topic Set Shape Orientation (Read 1013 times)
Kuzya
Jul 17th, 2018 at 7:49am
I want to set Shape Orientation.
IIs it possible that element set up in the other direction?
i need -> Bild1
i have -> Bild2
Kuzya
Lyubo
MindFusion team
Re: Set Shape Orientation
Reply #1 - Jul 17th, 2018 at 9:55am
You can set the shapeOrientation property of a Shape object to rotate it. For example:
Code (Javascript)
node.getShape().shapeOrientation = 90; // this will rotate the shape 90 degrees clockwise.
For this particular shape, you could instead set the node's rotationAngle to 180 and the rotateText property to false:
Code (Javascript)
node.setRotationAngle(180);
node.setRotateText(false);
Lyubo
« Last Edit: Jul 17th, 2018 at 12:01pm by Lyubo »
