Normal Topic Virtual Keyboard (Read 3382 times)
Manjula
Virtual Keyboard
Jul 19th, 2018 at 1:28pm
I am using virtual keyboard in standalone mode and on text box focus opening a window which contains virtual keyboard. Everything works fine till this point.
However when i place a regular wpf button on the window and try to call window.close its not firing. Interesting part is that if I debug the code, then that window will close but not in the not mode.
What could be the problem.
Manjula
Re: Virtual Keyboard
Reply #1 - Jul 19th, 2018 at 2:09pm
Is that button located on the keyboard's or main window, and do you mean you are calling window.Close from button's Click event handler?
Manjula
Reply #2 - Jul 23rd, 2018 at 3:58pm
I have a regular button and virtual keyboard stacked vertically in a wpf window. On click of button I am calling window.close, which is doesn't close the window. If I remove virtual keyboard from the same window and run. Window will be closed on click of the button.
Manjula
Reply #3 - Jul 24th, 2018 at 10:45am
The button is closing the window in my test project attached here.
TestStandalone.zip (Attachment deleted)
