Normal Topic How does scrolling work (Read 1730 times)
Kuzya
Aug 8th, 2018 at 2:32pm
We also use the complete available area of diagram
We also use a complete available area of diagrams. And we want to scroll right and down.
i use the following method:
this.diagram.setAutoResize(MindFusion.Diagramming.AutoResize.RightAndDown);
this.diagram.setAutoScroll(true);
and
  <div style="position: absolute; left: 0px; top: 33px; right: 0px; bottom: 0px; overflow: auto">
but scrolling does not work!
what am I doing wrong?
Kuzya
Re: How does scrolling work
Reply #1 - Aug 9th, 2018 at 9:12am
Auto-scrolling works in my test, it happens when you drag a node near or outside the div's edges. Is this what's not working for you?
Kuzya
Reply #2 - Aug 9th, 2018 at 11:38am
yeah, that's not working for me.
We take an element and move the element to the bottom or to the right behind the border. the scrollbars should move automatically.
We want to use the whole work surface.
In demo version (Flowcharter) the area is cut off from the right.
Kuzya
Reply #3 - Aug 10th, 2018 at 9:08am
Initial value of diagram.bounds.width is 210 in that sample, so if you view it in a larger browser window, the diagram will not cover all of the parent div. You could call diagram.setBounds with a large enough value to cover the div, converting pixels to current units using clientToDoc function. Check examples here showing that -
https://mindfusion.eu/Forum/YaBB.pl?num=1376539327/1#1
https://mindfusion.eu/Forum/YaBB.pl?num=1358356435/4#4
AutoScroll and AutoResize are enabled by default, and that works in same flowcharter example. If it's not working for you, please let me know browser version. If flowcharter auto-scrolls but your project does not, please attach a test page with same DOM setup as yours to reproduce it.
