Normal Topic How to prevent editing of control points of a link (Read 1608 times)
Dirk Woelfel
Aug 26th, 2018 at 6:38pm
I use control points of a link to obtain a special representation. I create these control points by source code and they should not be able to be changed interactively by the user.
How can I ensure that the user can mark the link (e.g. to delete it), but the control points are not displayed or cannot be moved by the user?
Regardless of the selected handle style, the control points are always visible and movable.
Thank you very much,
Dirk
Lyubo
MindFusion team
Re: How to prevent editing of control points of a link
Reply #1 - Aug 27th, 2018 at 1:14pm
You can use LinkStartModifying event and cancel user interactions, which attempt to move the link. For example:
private void _diagram_LinkStartModifying(object sender, LinkValidationEventArgs e)
    e.Cancel = true;
    e.CancelDrag();
Users will still be able to select and delete links even with this handler. To hide handles set the HandlesStyle to Invisible.
Lyubo
Dirk Woelfel
Reply #2 - Sep 10th, 2018 at 3:56pm
Thanks a lot! It works.
Dirk
