Normal Topic Export to pdf fails with non-printing characters (Read 4069 times)
David Long
Aug 28th, 2018 at 9:47am
When I export a chart to pdf and one of the chart boxes contains bullet point characters that came from a MS Word document, then the whole program shuts down without even an exception to catch. Code is:
var pdf = new PdfExporter();
try
pdf.Export(FlowChart, dlg.FileName);
catch (Exception ex)
MessageBox.Show(this, "Failed to export file, error is: " + ex.Message, "Error Message",
MessageBoxButtons.OK, MessageBoxIcon.Error);
I can't paste in the offending text, but a screenshot is attached
David L
Lyubo
MindFusion team
Re: Export to pdf fails with non-printing characters
Reply #1 - Aug 28th, 2018 at 12:02pm
I wasn't able to reproduce this with default settings and a node containing Unicode bullet characters • (U+2022).
Could you please attach here a diagram xml containing a node with such text that causes the crash here or mail it at support@mindfusion.eu, so that we can investigate.
Lyubo
David Long
Reply #2 - Aug 28th, 2018 at 1:18pm
Interestingly it seems to be a different type of bullet point that is the problem.  Word document attached containing the problem character.  Paste this text into a ShapeNode and export as pdf. There is a long pause and the program shuts down.
DavidL
Lyubo
MindFusion team
Reply #3 - Aug 28th, 2018 at 2:17pm
We were able to reproduce the issue with the bullets in the attached file. Our developer will investigate what's going wrong.
Lyubo
Lyubo
MindFusion team
Reply #4 - Aug 30th, 2018 at 5:11am
Try setting the default exporter encoding to Unicode and the bullet characters should export without errors. You will need to also set the AutoDetectEncoding flag to false:
PdfExporter pdfExp = new PdfExporter();
pdfExp.AutoDetectEncoding = false;
pdfExp.DefaultEncoding = System.Text.Encoding.Unicode;
pdfExp.Export(diagramView1.Diagram, saveFileDialog.FileName);
Lyubo
« Last Edit: Aug 30th, 2018 at 7:30am by Lyubo »
David Long
Reply #5 - Sep 8th, 2018 at 11:37am
No crash this time, but viewing the pdf in my default pdf viewer (MS Edge) shows all characters as blocks. Screenshot attached.  Sorry for delay in replying - does the 'Check this if you want to be informed...' feature work?
DavidL
Lyubo
MindFusion team
Reply #6 - Sep 10th, 2018 at 10:52am
It seems Edge has indeed some trouble displaying this text with Unicode encoding. Other pdf viewers under the same system don't seem to have that problem. We will investigate why this happens, in the mean time you can try replacing the square bullet with a regular one before export and reverting to the default encoding settings:
foreach (DiagramNode node in diagram1.Nodes)
    if (!(node is ShapeNode))
        continue;
    var snode = node as ShapeNode;
    if (snode.Text.Contains("\u25AA"))
        snode.Text = snode.Text.Replace('\u25AA', '\u2022');
About the forum notifications, it seems they broke with a update of our hoster's Perl version some time ago, so that feature doesn't work at the moment.
Lyubo
David Long
Reply #7 - Sep 11th, 2018 at 9:38am
There are two other types of bullet point that cause the same problem. Maybe there are other characters as well. I'll wait for a more robust solution.
DavidL
