Hot Topic (More than 10 Replies) Set diagramm position (Read 4339 times)
Olejan
Sep 11th, 2018 at 3:47pm
Helo!
How can I move given diagram to the position I need as it did for a node - node.Move(x, y)?
For example, I need to place three different diagrams one after another
Online
Re: Set diagramm position
Reply #1 - Sep 11th, 2018 at 4:17pm
These are sub-graphs in same Diagram instance, right? If you don't mind changing items' Selected value temporarily, you could use this method to move whole selection of items -
https://mindfusion.eu/Forum/YaBB.pl?num=1227100075/1#1
Olejan
Reply #2 - Sep 12th, 2018 at 12:16pm
Thanks a lot  Smiley
Olejan
Reply #3 - Sep 14th, 2018 at 1:49pm
New question, how to connect node TO2 to TO3 and TO4 to TO5? I know how to delete connection, but I don't know how to create it. When I use
Diagram1.Factory.CreateDiagramLink(TO2, TO3)
it has no effect. Maybe I forgot to use some code?
Please help me
Online
Reply #4 - Sep 14th, 2018 at 2:46pm
Have you added TO2 and TO3 to the diagram before calling CreateDiagramLink?
Olejan
Reply #5 - Sep 14th, 2018 at 2:53pm
Yes
Online
Reply #6 - Sep 14th, 2018 at 3:00pm
Does CreateDiagramLink return null?
Olejan
Reply #7 - Sep 14th, 2018 at 3:11pm
No. The link that was returned is not null. But Diagram1.Links.Count before creating the link and after that remained the same. And a view of Diagram was not changed
Online
Reply #8 - Sep 14th, 2018 at 5:37pm
This will happen only if origin or destination nodes are not found in diagram.Items at the time when you call CreateDiagramLink. If you believe otherwise, please attach test project demonstrating that.
Btw. if you set diagram.ValidityChecks to false, the link will be added even if the nodes are missing.
Olejan
Reply #9 - Sep 17th, 2018 at 12:34pm
You're right. The destination node was not found.
Another question - what is the right way to disconnect two nodes? I have to remove link from the diagram.Links, or I have to remove it from both nodes too?
Online
Reply #10 - Sep 18th, 2018 at 4:37am
Removing only from diagram.Links should be enough.
Olejan
Reply #11 - Sep 18th, 2018 at 3:11pm
Thank you very much for your help!
