Normal Topic PDF is not working on shared hosting (Read 2947 times)
Xamarin
Sep 13th, 2018 at 5:52am
I am using your Diagramming tools for asp.net. I have a web application hosted on asphostportal.com (web sites). When I try to export a diagram to pdf it gives me the error showed in the first attachment. However the pdf is generated but without the labels. I remember having a similar issue when using the DevExpress reporting components and those guys then came with a fix. I can help you fix the issue.
Note that the diagram used currently does not have icons so it's pretty normal that there are no icons inside the generated pdf file.
Re: PDF is not working on shared hosting
Reply #1 - Sep 13th, 2018 at 7:34am
Try the SuppressUnmanagedCode property -
https://mindfusion.eu/Forum/YaBB.pl?num=1389348420/3#3
