Normal Topic Self looping links (Read 1758 times)
Davaaron
Self looping links
Sep 25th, 2018 at 4:03pm
I'm trying to set the control points of self looping links. Right now, the self loop link is at the top (the default behaviour).
I want it to be a straight line from left to right through the node.
I tried
Code (Javascript)
    link.setOriginAnchor(0);
        link.setDestinationAnchor(0);
        link.updateFromPoints();
and
Code (Javascript)
        newPoints.push(new Point(20, 50));
        newPoints.push(new Point(70, 50));
        link.setControlPoints(newPoints);
but i has not effect.
By the way, what are the coordinates for the control points? Relative to the origin? Doc or client?
Re: Self looping links
Reply #1 - Sep 26th, 2018 at 12:28pm
At what point are you calling that code? The link might reset its shape if it becomes self-loop after the code runs.
Also the link might refuse your points if the array does not contain enough elements for link's Shape. E.g. Bezier links must specify 3 additional points for each segment after the first point, and Cascading links must contain at least 3 points to form their bend.
Coordinates are relative to diagram's (0,0) point, wherever it is located within diagram.Boudns, and specified in MeasureUnit units.
Davaaron
Reply #2 - Sep 26th, 2018 at 2:28pm
I'm calling that at last statement within the linkCreated event.
I will try out to add more points because I use Cascading for the links. Thanks for the hints.
