Normal Topic Some troubles migrating form v3.3 to 3.5 (Read 3489 times)
PDM.
Senior Member
Oct 8th, 2018 at 12:26am
Hello!!
Im back, hoppe Stoyo and Slavcho remember to me lol Smiley
Here some troubles:
protected override InteractionState StartDrawCommon(Point point, MindFusion.Diagramming.Wpf.MouseButton button)
           var state = base.StartDrawCommon(point, button);
Resizing = state != null &&
state.Action == MindFusion.Diagramming.Wpf.Action.Modify && state.AdjustmentHandle < 8;
           return state;
Operator '<' cannot be applied to operands of type 'AdjustmentHandle' and 'int'
private void form_HitTestAdjustmentHandles(object sender, HitTestEventArgs e)
var node = e.Item as DiagramNode;
var size = new Size(20, 20);
Rect r = e.Item.GetBounds();
if (r.Contains(e.MousePosition))
e.HitResult = 8; //error here
if (node != null)
var x = e.MousePosition.X;
var y = e.MousePosition.Y;
var location = node.Bounds.Location;
var diagOffset = new Vector(location.X, location.Y);
double rotationAngle = node.RotationAngle;
Point localPoint = RotatePointAt(e.MousePosition, node.GetCenter(), -rotationAngle);
if (r.Contains(localPoint))
localPoint = localPoint - diagOffset;
for (int i = 0; i < 8; i++)
var point = CustomHandlePosition(i, node.Bounds, size);
var rect = new Rect(point, size);
if (rect.Contains(localPoint))
e.HitResult = i; //error here
var std = StdHandlePosition(i, node.Bounds);
MyBehavior.MouseDX = std.X - localPoint.X;
MyBehavior.MouseDY = std.Y - localPoint.Y;
break;
Cannot implicitly convert type 'int' to 'MindFusion.Diagramming.Wpf.AdjustmentHandle'
I testing with the trial version.
How much cost update?
Re: Some troubles migrating form v3.3 to 3.5
Reply #1 - Oct 8th, 2018 at 9:29am
Pablo, that you? Tongue Adjustment handles are now represented using classes and enums instead of integer values. Try this for the StartDrawCommon override -
protected override InteractionState StartDrawCommon(Point point, MouseButton button)
	Resizing =
		state != null && state.Action == Action.Modify &&
		!state.AdjustmentHandle.IsMoveHandle();
	return state;
e.HitResult = NodeAdjustmentHandle.Move;
//instead of e.HitResult = 8
Try replacing the i < 8 loop with this one -
foreach (NodeHandleType handleType in Enum.GetValues(typeof(NodeHandleType)))
//and then
e.HitResult = new NodeAdjustmentHandle(handleType);
Also replace parameters of your CustomHandlePosition and StdHandlePosition functions with NodeHandleType instead of int.
PDM.
Senior Member
Reply #2 - Oct 8th, 2018 at 11:00am
Yes its me, and I can prove, Im lost with the loop part and after.  Cheesy
            if (node != null)
                   e.HitResult = i;
                   break;
   Point CustomHandlePosition(int handleId, Rect nodeBounds, Size size)
       if (handleId == 0)
           return new Point(0, 0);
       if (handleId == 4)
           return new Point(nodeBounds.Width / 2 - size.Width / 2, 0);
       if (handleId == 1)
           return new Point(nodeBounds.Width - size.Width, 0);
       if (handleId == 7)
           return new Point(0, nodeBounds.Height / 2 - size.Height / 2);
       if (handleId == 5)
           return new Point(nodeBounds.Width - size.Width, nodeBounds.Height / 2 - size.Height / 2);
       if (handleId == 3)
           return new Point(0, nodeBounds.Height - size.Height);
       if (handleId == 6)
           return new Point(nodeBounds.Width / 2 - size.Width / 2, nodeBounds.Height - size.Height);
       if (handleId == 2)
           return new Point(nodeBounds.Width - size.Width, nodeBounds.Height - size.Height);
       return new Point();
   Point StdHandlePosition(int handleId, Rect nodeBounds)
       if (handleId == 0)
       if (handleId == 4)
           return new Point(nodeBounds.Width / 2, 0);
       if (handleId == 1)
           return new Point(nodeBounds.Width, 0);
       if (handleId == 7)
           return new Point(0, nodeBounds.Height / 2);
       if (handleId == 5)
           return new Point(nodeBounds.Width, nodeBounds.Height / 2);
       if (handleId == 3)
           return new Point(0, nodeBounds.Height);
       if (handleId == 6)
           return new Point(nodeBounds.Width / 2, nodeBounds.Height);
       if (handleId == 2)
           return new Point(nodeBounds.Width, nodeBounds.Height);
       return new Point();
   void form_DrawAdjustmentHandles(object sender, DrawItemEventArgs e)
       var size2 = new Size(form.AdjustmentHandlesSize, form.AdjustmentHandlesSize);
       var size = new Size(handlersize, handlersize);
       if (node != null)
           var TopLeft = new Point(0, 0);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopLeft, size));
           var TopMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, 0);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopMiddle, size));
           var TopRight = new Point(node.Bounds.Width - size.Width, 0);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopRight, size));
           var MiddleTop = new Point(0, node.Bounds.Height / 2 - size.Height / 2);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(MiddleTop, size));
           var MiddleBott = new Point(node.Bounds.Width - size.Width, node.Bounds.Height / 2 - size.Height / 2);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(MiddleBott, size));
           var bottomLeft = new Point(0, node.Bounds.Height - size.Height);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomLeft, size));
           var bottomMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, node.Bounds.Height - size.Height);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomMiddle, size));
           var bottomRight = new Point(node.Bounds.Width - size.Width, node.Bounds.Height - size.Height);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomRight, size));
   Point RotatePointAt(Point point, Point pivot, double angle)
       Matrix rotation = new Matrix();
       rotation.RotateAt(angle, pivot.X, pivot.Y);
       Point res = rotation.Transform(point);
       return res;
I sent a private message later Smiley
Reply #3 - Oct 9th, 2018 at 10:47am
So change your methods to
Point CustomHandlePosition(NodeHandleType handleId, Rect nodeBounds, Size size)
	if (handleId == NodeHandleType.ResizeTopLeft)
	if (handleId == NodeHandleType.ResizeTopCenter)
	if (handleId == NodeHandleType.ResizeTopRight)
	if (handleId == NodeHandleType.ResizeMiddleLeft)
	if (handleId == NodeHandleType.ResizeMiddleRight)
	if (handleId == NodeHandleType.ResizeBottomLeft)
	if (handleId == NodeHandleType.ResizeBottomCenter)
	if (handleId == NodeHandleType.ResizeBottomRight)
	return new Point();
Point StdHandlePosition(NodeHandleType handleId, Rect nodeBounds)
	return new Point();
and the loop becomes
	var point = CustomHandlePosition(handleType, node.Bounds, size);
		var std = StdHandlePosition(handleType, node.Bounds);
		break;
PDM.
Senior Member
Reply #4 - Jan 19th, 2019 at 3:27am
OK, thanks finally working.
But there is 2 troubles:
1: If I rotate the node, example 90 degrees, when try resize....the node do rare jumps constraining a little bit in size. This is a older bug I have and never be able to solve.
2:  This not happen before, and start with this change.
If I select multiple objects, before this change I can resize all selected nodes.
For sure I can do now, but the mouse pointer instead to show resize pointer when resize all selected nodes, show cross move pointer. Not  a big issue, just is a little ugly.
PDM.
Senior Member
Reply #5 - Jan 23rd, 2019 at 4:49am
Please need some help with  this issues.
Reply #6 - Jan 23rd, 2019 at 12:21pm
I can't see any problems while resizing rotated node, please attach a test project reproducing that.
Add this to your behavior class to show resize cursors -
public override CursorHint SetMouseCursor(Point point, out bool startInteraction)
    if (Diagram.AllowMultipleResize)
        AdjustmentHandle handle = Diagram.Selection.HitTestHandle(point);
        if (handle != null)
            startInteraction = true;
            return SetModfCursor(point, handle, true, false);
    return base.SetMouseCursor(point, out startInteraction);
