Normal Topic DiagramView.getItemAt() (Read 4391 times)
reedm60
Nov 17th, 2018 at 12:25am
Does anyone have any examples of using DiagramView.geItemAt(PointF, Boolean, Boolean);?
I call it using the event.getRawX() and event.getRawY() values returned in the MotionEvent object passed into the onTouchEvent(View, MotionEvent) and it never returns the DiagramItem I am touching.
Do I need to turn some option on or convert the x,y values to some thing else?
Thanks!
reedm60
Re: DiagramView.getItemAt()
Reply #1 - Nov 17th, 2018 at 2:43pm
Here is the code for the onTouchEvent
@Override
public boolean onTouchEvent(View v, MotionEvent event) {
      // This line always returns null for 'di'
      DiagramItem di = mDiagramView.getItemAt(new PointF(event.getRawX(), event.getRawY()), true);
Why is the DiagramItem returned from getItemAt() always null?
reedm60
Reply #2 - Nov 18th, 2018 at 3:29pm
Ah ha!  I got it.
If I use event.getX() and event.getY(), it works.
Reply #3 - Nov 19th, 2018 at 7:18am
I can't see getItemAt method in DiagramView class, is it your custom method? There's Diagram.getItemAt method and it expects coordinates specified in diagram's MeasureUnit, while the View.onTouchEvent override probably gives you Android's device pixels. See if diagram events like DiagramListener.nodeClicked won't work better for you, or otherwise try converting pixels to diagram coordinates using DiagramView.deviceToDoc. You can find an example with deviceToDoc used here -
https://mindfusion.eu/Forum/YaBB.pl?num=1432073553/3#3
reedm60
Reply #4 - Nov 19th, 2018 at 4:06pm
Thank you.  I meant Diagram.getItemAt() not DiagramView.
