Normal Topic How to get all node (Read 1439 times)
oxzorxxo
How to get all node
Dec 1st, 2018 at 12:54am
how to get all node to get shape name and to count all nodes ... i want to do something like if node shapeid then
thank you in advance
Lyubo
MindFusion team
Re: How to get all node
Reply #1 - Dec 3rd, 2018 at 7:34am
Try this:
Code (Javascript)
for (var i = 0; i < diagram.getNodes().length; i++)
    var node = diagram.getNodes()[i];
    // test if the node is a ShapeNode instance
    if (!MindFusion.AbstractionLayer.isInstanceOfType(MindFusion.Diagramming.ShapeNode, node))
        continue;
    // check the shape id of the node here
    if (node.getShape().getId() == "...")
Lyubo
oxzorxxo
Reply #2 - Dec 29th, 2018 at 12:15pm
thank you
