Normal Topic How do I override the LoadFromXml method in Diagram? (Read 1153 times)
chowy
Dec 6th, 2018 at 3:14am
I inherited the diagram, and then I wrote some of my own properties that need to be saved to the xml. But I did not see loadfromxml can be override .
Re: How do I override the LoadFromXml method in Diagram?
Reply #1 - Dec 6th, 2018 at 4:26pm
This build makes LoadFromXml virtual -
https://mindfusion.eu/_beta/wpfdiag354.zip
public class MyDiagram : Diagram
	public override void SaveToXml(XmlDocument document)
		base.SaveToXml(document);
		var ctx = new XmlPersistContext(
			this, document, XmlPersistContext.LatestFormat);
		ctx.WriteString("test", "Test1", document.DocumentElement);
		ctx.WriteInt(2, "Test2", document.DocumentElement);
	public override void LoadFromXml(XmlDocument document)
		base.LoadFromXml(document);
		var test1 = ctx.ReadString("Test1", document.DocumentElement);
		var test2 = ctx.ReadInt("Test2", document.DocumentElement);
		Debug.WriteLine(test1);
		Debug.WriteLine(test2);
