Normal Topic NodePointed event fired after a delay (Read 1574 times)
VM
Dec 13th, 2018 at 5:27pm
I am trying to turn the cursor to hand when the mouse is over a table cell. I subscribed to NodePointed event. It gets fired after a significant delay (1sec +).
The event handler code:
                 if(e.Node is TableNode)
                       TableNode table = e.Node as TableNode;
                       int row = -1;
                       int col = -1;
                       table.CellFromPoint(e.MousePosition, ref row, ref col);
                       if(col == 1)
                             Cursor.Current = Cursors.Hand;
Any suggestions,
Thank you in advance,
Re: NodePointed event fired after a delay
Reply #1 - Dec 14th, 2018 at 1:12pm
It's raised after the mouse pointer rests for 800ms over a node. If you need to detect it immediately, call GetNodeAt from MouseMove handler. E.g. see example here -
https://mindfusion.eu/Forum/YaBB.pl?num=1357667823/1#1
