Normal Topic Vector is not defined in defenitions ts file (Read 1036 times)
Ankur shah
Jan 11th, 2019 at 11:31am
Can you please provide me the definitions file which is having Vector declared in it. The definition file which is not having vector in it. Please have a look at the attached file.
Using this import : import Vector = MindFusion.Drawing.Vector;
Lyubo
MindFusion team
Re: Vector is not defined in defenitions ts file
Reply #1 - Jan 11th, 2019 at 2:00pm
Please find attached to this post the latest version of the definitions files, which include the Vector class. Please note, that the definitions are now separated in two files - jsdiag.d.ts and jscommon.d.ts and you must use both files in your project from now on.
Lyubo
