Normal Topic drag and drop (Read 1549 times)
Trupti
drag and drop
Mar 1st, 2019 at 5:01am
Is there any way to find out if the dragged node is dropped on upper part or lower part of a node? See the attachment.
Thanks in advance..Smiley
Lyubo
MindFusion team
Re: drag and drop
Reply #1 - Mar 1st, 2019 at 9:59am
You can hit-test for the nodes under the cursor by using diagram.getNodesAt method and than check where on the hit node the point under the cursor lies. You can try that from a nodeModifed handler for example:
Code (Javascript)
var Events = MindFusion.Diagramming.Events;
diagram.addEventListener(Events.nodeModified, function(sender, args) {
    if (args.getAdjustmentHandle() == 8) { // Move action
        var draggedNode = args.getNode(),
              location = args.getMousePosition(),
              hitNodes = diagram.getNodesAt(location);
        if (hitNodes.length > 1) {
            for (var i = 0; i < hitNodes.length; i++) {
                if (hitNodes[i] == draggedNode)
                    continue;
                var bounds = hitNodes[i].getBounds();
                if (location.y <= (bounds.y + bounds.height / 2))
                    console.log('top half');
                else
                    console.log('bottom half');
Lyubo
Trupti
Re: drag and drop
Reply #2 - Mar 1st, 2019 at 12:23pm
Thank You for the Response!! Smiley
