Normal Topic After Drop is Completed, I Need to Deselect Node in NodeListView (Read 987 times)
alukes
Mar 11th, 2019 at 9:01pm
When I start a drag and drop, the node in the node list view is selected, which is fine, However, it stays selected after the drag and drop operation is completed.
How do I unselect the selected node in the node list view?
Lyubo
MindFusion team
Re: After Drop is Completed, I Need to Deselect Node in NodeListView
Reply #1 - Mar 12th, 2019 at 6:46am
You can call the selectItem method on the NodeListView control with a null argument, after you've completed your drag and drop operation.
Code (Javascript)
nodeList.selectItem(null); // this will deselect the items in the list
Lyubo
