Normal Topic SetZoomLevel Doesn't Have an Effect on the Diagram (Read 1210 times)
alukes
Mar 13th, 2019 at 11:21pm
Using 3.3 version
I have the following in document.onReady function
diagram.setZoomLevel(500);
I change the value and it has no effect on the size of the nodes.
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Re: SetZoomLevel Doesn't Have an Effect on the Diagram
Reply #1 - Mar 14th, 2019 at 6:53am
Did you try zoom factor like this,
    let zoomFactor: number = this.diagram.getZoomFactor();
    this.diagram.setZoomFactor(zoomFactor + 10);
Kannan
Lyubo
MindFusion team
Reply #2 - Mar 14th, 2019 at 11:00am
Setting zoom level works as expected in my test. Can you verify that there are not errors or exceptions in the browser console happening, prior to calling setZoomLevel? Also, the zoom factor may get overwritten if you load a diagram from json/xml after you've set it in code. If you restore the diagram document from file, try moving the zoom assignment after it's been loaded.
Lyubo
