Page Index Toggle Pages: [1] 2 3 4 Send TopicPrint
Very Hot Topic (More than 25 Replies) To highlight a composite node/link/label when selected ! (Read 28150 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Mar 15th, 2019 at 11:06am
I've defined a composite node like this.
OrgChartNode = CompositeNode.classFromTemplate("OrgChartNode",
component: "GridPanel",
rowDefinitions: ["*"],
columnDefinitions: ["22"],
children:
rowDefinitions: ["18", "5"],
columnDefinitions: ["18", "5"],
children:
gridColumn: 0,
component: "Image",
autoProperty: true,
margin: "3",
imageAlign: "TopLeft"
gridColumn: 0,
component: "Image",
autoProperty: true,
margin: "3, 3, 0, 0",
gridColumn: 0,
component: "Text",
autoProperty: true,
text: "title",
margin: "3, 40, 0, 0",
font: "Verdana 12px",
textAlign: "BottomLeft"
I want to highlight the node when selected. I tried setting stroke like this, but didn't work. Any idea?
var node = new this.OrgChartNode();
var compNode = node as CompositeNode;
compNode.setStroke("#FFFFFF");
compNode.setStrokeThickness(5);
Kannan
« Last Edit: Jun 26th, 2019 at 12:45pm by Kannan Thirumal »
Lyubo
MindFusion team
Re: To highlight a composite node when selected !
Reply #1 - Mar 15th, 2019 at 12:48pm
You can add a Rect component to the template, and set its pen and strokeThickness properties:
Code (Javascript)
    component: "Rect",
    pen: "#FFF",
    strokeThickness: 5
If you have more than 1 row/column in the template, you can set its rowSpan/columnSpan properties respectively.
Lyubo
Kannan Thirumal
Senior Member
Reply #2 - Mar 15th, 2019 at 1:25pm
I've defined like this but didn't work. Any idea?
children:
children:
gridColumn: 0,
component: "Rect",
pen: "black",
//stroke: "black",
strokeThickness: 5,
gridColumn: 0,
component: "Image",
autoProperty: true,
margin: "3",
gridColumn: 0,
component: "Image",
autoProperty: true,
gridColumn: 0,
component: "Text",
autoProperty: true,
text: "title",
Kannan
Lyubo
MindFusion team
Reply #3 - Mar 19th, 2019 at 11:40am
We've adjusted the Tutorial3 sample from the JsDiagram package to show one way you can implement highlighting for CompositeNode. You can download it here.
Lyubo
Kannan Thirumal
Senior Member
Reply #4 - Jun 11th, 2019 at 12:13pm
I'm highlighting the node on selection by the following code,
this.diagram.addEventListener(Event.nodeSelected, (sender, args) => {
var node = args.getNode();
this.selectNode(node);
this.diagram.addEventListener(Event.nodeDeselected, (sender, args) => {
this.deselectNode(node);
private selectedNode: any;
private selectNode(node): void {
var background = node.getComponent("Background");
background.pen = "Orange";
background.strokeThickness = 5;
background.margin.right = -node.bounds.width + 18;
background.margin.bottom = -node.bounds.height + 12;
node.invalidate();
private deselectNode(node): void {
background.pen = "white";
background.strokeThickness = 0;
node.invalidate();
This is working fine. But when selecting another node, the previous node selection is not clearing properly. Please check the attached screen shot Node Selection Background Issue.png.
Also when doing multiple select using mouse drag, the mouse drag is still continuing and it is not releasing. That is the selection rectangle is moving along with the mouse. Please check the attached screen shot Mouse Multi Select Issue.png.
I've uploaded the sample in the below path,
https://drive.google.com/open?id=1yu5xlJn3aqoBzXnKvcrUZ177vETo3M1i
Kannan
Online
Reply #5 - Jun 11th, 2019 at 6:11pm
The "Background" rect from your node template does not fit inside node's Bounds due to the fixed row/column sizes, and latest version repaints only the area of node.Bounds, so the rect's part that sticks out doesn't get refreshed. Try using * instead of fixed sizes in row/col definitions to make the rows and columns resize with the node.
Actually I'm not seeing any reason for the nested grids in the template.txt and using two rows and columns if you only need to display a rectangle with image inside; try a single SimplePanel having the Rect and Image components as its children.
Alternatively if you really need the frame rectangle to be drawn outside of node.Bounds, you will have to override the DiagramNode.getRepaintBounds method and return a larger rectangle.
The selection will keep getting drawn if some error happens during processing of mouse-up events. Try enabling stop-on-error in your browser's debugger and check the top of the call stack to see what's wrong.
Lyubo
MindFusion team
Reply #6 - Jun 12th, 2019 at 8:00am
Kannan Thirumal wrote on Jun 11th, 2019 at 12:13pm:
The selection stops, because the interaction goes out of the bounds of the diagram canvas. To prevent that, set a bigger bounds rectangle for the diagram.
Lyubo
Kannan Thirumal
Senior Member
Reply #7 - Jun 13th, 2019 at 11:49am
I increased the width/height of canvas and tried. Still same is happening.
Please check the sample to reproduce the issue: https://drive.google.com/open?id=1yu5xlJn3aqoBzXnKvcrUZ177vETo3M1i
Kannan
Online
Reply #8 - Jun 14th, 2019 at 9:37am
You can make the diagram's area larger by calling diagram.setBounds(new Rect(...)); Assigning canvas element's width and height will have no effect since the Bounds value overwrites them.
Kannan Thirumal
Senior Member
Reply #9 - Jun 17th, 2019 at 6:37am
This is happening because of the node highlight-logic below,
node.invalidate();
node.invalidate();
This was suggested on this post on Mar 19th, 2019 at 12:40pm.
Is there any other way to highlight a selected node?
I'm not sure the below code also not working for node selection?
Kannan
Kannan Thirumal
Senior Member
Reply #10 - Jun 17th, 2019 at 12:42pm
After setting diagram bounds also I'm having the same issue. I've attached the sample to reproduce the issue. Please check it,
     https://drive.google.com/open?id=1LL3Ev1_gEdohu3kJGqW8UXNmWLJ2OnCw
Kannan
Slavcho wrote on Jun 14th, 2019 at 9:37am:
Lyubo
MindFusion team
Reply #11 - Jun 17th, 2019 at 1:06pm
You can make the highlight utilizing the custom drawing adjustment handles technique:
Code (Javascript)
// Subscribe to the drawAdjustmentHandles and hitTestAdjustmentHandles events.
diagram.addEventListener(MindFusion.Diagramming.Events.drawAdjustmentHandles, onDrawHandles);
diagram.addEventListener(MindFusion.Diagramming.Events.hitTestAdjustmentHandles, onHitTestHandles);
// drawAdjustmentHandles handler
function onDrawHandles(sender, args)
	var bounds = args.node.getBounds();
	var context = args.context;
	var size = args.node.parent.getAdjustmentHandlesSize();
	var halfsize = size / 2;
	// draw the highlight
	context.save();
	context.fillStyle = "#ce0000"; //highlight brush
	context.fillRect(bounds.x - halfsize, bounds.y - halfsize, bounds.width + size, size);
	context.fillRect(bounds.x - halfsize, bounds.y - halfsize, size, bounds.height + size);
	context.fillRect(bounds.x - halfsize, bounds.y + bounds.height - halfsize, bounds.width + size, size);
	context.fillRect(bounds.x + bounds.width - halfsize, bounds.y - halfsize, size, bounds.height + size);
	context.restore();
	// Draw the regular handles
	args.node.handlesStyle = MindFusion.Diagramming.HandlesStyle.SquareHandles;
	MindFusion.Diagramming.HandleUtils.drawSquareHandles(context, args.node);
	args.node.handlesStyle = MindFusion.Diagramming.HandlesStyle.Custom;
// hitTestAdjustmentHandles handler
function onHitTestHandles(sender, args)
	var node = args.node;
	var mousePosition = args.mousePosition;
	// Temporarily set the handles style to default to perform hit-testing
	var result = MindFusion.Diagramming.HandleUtils.pointInHandle(mousePosition, node);
	if (result)
		return args.setAdjustmentHandle(result.index);
// set the item's handles style
node.setHandlesStyle(MindFusion.Diagramming.HandlesStyle.Custom);
The HandleUtils class is currently not available in the TypeScript definitions file, so you'll need to add it via declaration merging.
Lyubo
Kannan Thirumal
Senior Member
Reply #12 - Jun 17th, 2019 at 1:33pm
I'm getting this compile error,
ERROR in src/app/diagram/diagram.component.ts(85,28): error TS2339: Property 'HandleUtils' does not exist on type 'typeof Diagramming'.
src/app/diagram/diagram.component.ts(96,41): error TS2339: Property 'HandleUtils' does not exist on type 'typeof Diagramming'.
Please help me to fix this.
Kannan
Lyubo
MindFusion team
Reply #13 - Jun 17th, 2019 at 2:16pm
Kannan Thirumal wrote on Jun 17th, 2019 at 12:42pm:
Kannan
Your application gives error, because you're calling getComponent method on DiagramNode and ShapeNode. This method is available only on CompositeNode. That's why the selection can't complete.
Lyubo
MindFusion team
Reply #14 - Jun 17th, 2019 at 4:13pm
Kannan Thirumal wrote on Jun 17th, 2019 at 1:33pm:
Kannan
You can use standard TypeScript declaration merging like this:
Code (Javascript)
declare module "diagram-library"
	namespace Diagramming
		class HandleUtils
			drawSquareHandles(context: CanvasRenderingContext2D, item: MindFusion.Diagramming.DiagramItem): void;
			pointInHandle(point: MindFusion.Drawing.Point, item: MindFusion.Diagramming.DiagramItem) : number;
If that doesn't work in your setup, you can always cast to any to avoid the compile-time errors, i.e. replace the HandleUtils calls in the example in the previous post with:
Code (Javascript)
(MindFusion.Diagramming["HandleUtils"] as any).drawSquareHandles(context, args.node);
var result = (MindFusion.Diagramming["HandleUtils"] as any).pointInHandle(mousePosition, node);
Lyubo
