Normal Topic Disable autorepeat for one key (Read 2358 times)
MisteryGuy_07
Mar 21st, 2019 at 10:17pm
It is possible to disable the autorepeat behaviour for one key? I seem to be getting an error where having auto repeat turned on while debugging triggers twice the key press.
Online
Re: Disable autorepeat for one key
Reply #1 - Mar 22nd, 2019 at 2:13pm
The AutoRepeat timer starts after KeyPressed event fires, so you could toggle AutoRepeat state from the KeyPressed handler:
void vk_KeyPressed(object sender, VirtualKeyEventArgs e)
    var rk = e.Key as RegularKey;
    if (rk != null && rk.UpperCase == "A")
        vk.AutoRepeat = true;
    else
        vk.AutoRepeat = false;
