Normal Topic Separating link arrows (Read 2362 times)
David Long
Mar 26th, 2019 at 8:28pm
I am drawing a diagram where nodes represent places and link arrows represent people or agents moving from one place to another. Obviously, a person can move from point A to point B and then the same or another person can move from point B to point A. In this case, very often, the link arrows overlap. Is there an easy way I can separate the link arrows so that they are all distinct. I am using various layout methods: circular, hierarchical, one-way,topological, cascade and layered.
DavidL
Re: Separating link arrows
Reply #1 - Mar 27th, 2019 at 9:17am
LinkPadding should take care of that when using LayeredLayout with LinkType = Cascading. For other layouts with cascading links, try calling OrtogonalRouter.Arrange after the main layout. For layouts that create straight-line inclined links, try code from https://mindfusion.eu/Forum/YaBB.pl?num=1374661504/1#1 , or convert them to Bezier shapes and apply https://mindfusion.eu/Forum/YaBB.pl?num=1227111424/1#1.
David Long
Reply #2 - Mar 27th, 2019 at 4:52pm
Thanks.  The solution with Bezier curves seems to work well.
DavidL
David Long
Reply #3 - Apr 12th, 2019 at 10:10am
Well I thought that is worked well, but it only seems to work with an even number of links between two boxes.  I'm doing a circular layout followed by using the code from:
to separate the links.  I think the line...
       if (commonLinks.Count % 2 == 0)
needs to be removed.  This seems to work much better.
DavidL
Reply #4 - Apr 12th, 2019 at 3:10pm
Maybe because the original code was for handling LinkCreated event where every new odd link is automatically centered between the even number of links from previous arrangements, and a new arrangement's needed only when they get even number again and last two overlapping Smiley So yes, for the general case where you arrange all links together, it's better to remove that check.
