Hot Topic (More than 10 Replies) How to show scroll bar in container node ! (Read 6783 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Apr 23rd, 2019 at 9:53am
   For fishbone diagram, we used mind fusion container node to hold parameters as shape nodes. It is working fine for the few parameters. We need to show scrollbar when there are more parameters. I've attached the sample project and screenshot of the sample. Please let me know how to solve this issue.
Thanks & Regards,
Kannan
Re: How to show scroll bar in container node !
Reply #1 - Apr 23rd, 2019 at 10:37am
Containers do not support scrolling at this time. Try showing the parameters in TableNodes instead, as shown in Inheritance.html example.
Kannan Thirumal
Senior Member
Reply #2 - Apr 23rd, 2019 at 12:30pm
     May I know when this will be supported?
     Also, Is there any workaround?
Kannan
Reply #3 - Apr 24th, 2019 at 7:56am
It won't be supported in short term. Workaround is to use a TableNode if you only need to show text labels (you can show images too in cells). Alternatively if you don't need to move the list of parameters around, you could show it in a second diagram instance where the diagram itself will scroll.
Kannan Thirumal
Senior Member
Reply #4 - May 2nd, 2019 at 6:43am
Hi Slavcho,
As per the reply which we got from forum, we are constructing the node with table node. There are few issues with respect to table node, mentioned below.
1.      Unnecessary space available in table node other than added cells. Following table node is added with 5(0 to 4) parameters and constructed as below
Sample Image Attached : Sample Image-1.png
But when scroll down to view the last one parameter unnecessary empty space exist as below.
Sample Image Attached : Sample Image-2.png
2.      For moving the scrollbar need to click on arrows only, cant able to move scrollbar by dragging.
3.      Scrollbar size(to reduce width) is not modifiable.
Please help me to solve these above mentioned issues.
Note: I've attached the sample project with this mail, please find it.
Kannan
Reply #5 - May 2nd, 2019 at 1:54pm
Dragging the scrollbar works for me, both with your test project and the Inheritance.html example. With what browser and operating system doesn't it work on your side?
Kannan Thirumal
Senior Member
Reply #6 - May 2nd, 2019 at 2:52pm
Did you tried with the attached MindFusion.Diagramming.js file?
Kannan
Reply #7 - May 3rd, 2019 at 7:49am
Yes, dragging works for me with your old version too. Only problem I can see is you have to drag a larger distance until it gets to move when the scroll range is small. Drag-scrolling should start faster when you have more table rows.
We'll have in mind properties for 1 an 3 for next release. At this time you could change this function to get a different width -
MindFusion.Diagramming.ScrollBar.prototype.getRect = function ()
	var node = this.node;
	var mm = GraphicsUnit.getMillimeter(node.parent.measureUnit);
	var rect = node.bounds;
	var capHeight = node.getCaptionHeight();
	return new Rect(
		rect.right() - 5 * mm,
		rect.y + capHeight,
		5 * mm,
		rect.height - capHeight);
Kannan Thirumal
Senior Member
Reply #8 - May 6th, 2019 at 7:26am
May I know why this happens?
1. Unnecessary space available in table node other than added cells. Following table node is added with 5 (0 to 4) parameters and constructed as below
Kannan
Kannan Thirumal wrote on May 2nd, 2019 at 6:43am:
Hi Slavcho,
Kannan
Reply #9 - May 6th, 2019 at 9:52am
It happens because the control treats table's scroll position as first visible row, and TableNode sets the number of rows as its scroll range. So when the first visible row is last table's row, the space below it remains unoccupied. We'd have to reduce the scroll range by some amount depending on height of table and rows to remove the empty space; we'll have that in mind for upcoming release.
Kannan Thirumal
Senior Member
Reply #10 - Aug 7th, 2019 at 9:27am
In some cases the scroll box in the vertical scroll bar of the table node is not shown. But when clicking the scroll arrow, the contents moves up and down. May I know why the scroll box is not shown?
Attached the screen shot and uploaded the sample code in the below url,
https://drive.google.com/open?id=1rprKbXRRmt79u8xMm2rhnA1JJQn32JQB
Kannan
Reply #11 - Aug 8th, 2019 at 6:37am
It might not be detecting that the scroll range has grown, depending on how you set up the table. Try calling TableNode.setCurrentScrollRow(0) after creating the table - that should recalculate scroll range and refresh the scrollbar appearance.
Kannan Thirumal
Senior Member
Reply #12 - Aug 8th, 2019 at 7:18am
I tried the same but still not shown. Could you please check the below code?
  drawTableNode() {
    var canvasParent = document.createElement("div");
    document.body.appendChild(canvasParent);
    let canvas = document.createElement("canvas");
    canvasParent.appendChild(canvas);
    this.diagram = Diagram.create(canvas);
    this.diagram.setMeasureUnit(GraphicsUnit.Pixel);
    this.diagram.setAutoScroll(true);
    this.diagram.setBehavior(MindFusion.Diagramming.Behavior.Modify);
    this.diagram.setAllowSelfLoops(false);
    var table1 = this.diagram.getFactory().createTableNode(400, 100, 150, 250);
    table1.redimTable(2, 9);
    (table1 as any).useScrollBars = true;
    table1.setScrollable(true);
    table1.setColumnWidth(0, 130);
    (MIND as any).ScrollBar.prototype.background = "#e0e9e9";
    (MIND as any).ScrollBar.prototype.foreground = "DarkGray";
    table1.setBrush("#FFFFFF");
    table1.setCaptionBackBrush("#c0c0c0");
    table1.setCaptionHeight(0);
    table1.setLocked(true);
    table1.setObstacle(true);
    table1.setAllowIncomingLinks(false);
    table1.setAllowOutgoingLinks(false);
    table1.setShadowColor("transparent");
    table1.setCellFrameStyle(MIND.CellFrameStyle.None);
    let nodes: Array<string> = ["Description", "Assay of Testosterone (%LC = 1% w/w)",
      "Assay of Alcohol (%LC = 67% w/w)", "Assay of Isopropyl myristate (%LC = 0.65% w/w)",
      "Related substances", "Content uniformity", "pH", "Viscosity", "Minimum fill volume"];
    for (let i = 0; i < nodes.length; i++) {
      let rowHeight = this.getRowHeight(nodes[i])
      table1.setRowHeight(i, rowHeight);
      var cell = table1.getCell(0, i);
      cell.setText(nodes[i]);
      cell.setTextColor("#000000");
      cell.setBrush("#ffffff");
      cell.setFont(new Font("verdana", 13, true));
    table1.setCurrentScrollRow(0);
Kannan
Lyubo
MindFusion team
Reply #13 - Aug 8th, 2019 at 8:31am
With the above code, the scroll thumb shows in my test (attached is a picture). I had to replace your getRowHeight method with a scalar value (60 in my case), since the code for that wasn't posted above.
Code (Javascript)
/*var rowHeight = this.getRowHeight(nodes[i])*/
table1.setRowHeight(i, 60/*rowHeight*/);
Lyubo
Kannan Thirumal
Senior Member
Reply #14 - Aug 8th, 2019 at 8:50am
Row height is calculated like this,
  getRowHeight(text: any) {
    let element = document.createElement("section");
    element.style.maxWidth = "125px";
    element.style.lineHeight = "20px";
    element.style.wordWrap = "break-word";
    element.style.fontSize = "13px";
    element.style.fontFamily = "Verdana";
    element.style.fontWeight = "bold";
    element.innerText = text;
    document.body.appendChild(element);
    let elementHeight = element.offsetHeight;
    var lineHeight = parseInt(element.style.lineHeight);
    var lines = elementHeight / lineHeight;
    document.body.removeChild(element);
    return (lines * 13) + 9;
Kannan
