Normal Topic dotted link (Read 3478 times)
liza
dotted link
May 1st, 2019 at 6:56am
Can I get dotted links instead of straight line for links?
AIM
Re: dotted link
Reply #1 - May 1st, 2019 at 7:02am
Call links' setStrokeDashStyle method.
liza
Re: dotted link
Reply #2 - May 1st, 2019 at 7:18am
Thanks, but please can you tell me how can I use it.
AIM
Re: dotted link
Reply #3 - May 1st, 2019 at 7:45am
function onLinkCreated(diagram, e)
    e.getLink().setStrokeDashStyle(MindFusion.Drawing.DashStyle.Dot);
liza
Re: dotted link
Reply #4 - May 1st, 2019 at 7:55am
Thanks Slavcho, but this appears to be very minute.  I want  big dashes with sufficient space between two dashes. Can I set dash width and space between two dashes?
AIM
Re: dotted link
Reply #5 - May 1st, 2019 at 9:01am
Try the Dash style instead of Dot, or otherwise replace the DashStyle.apply function with your own version. The standard one looks like this -
MindFusion.Drawing.DashStyle.apply = function (context, dashStyle)
	if (!context.setLineDash)
		return;
	var scale = 2 / context._mf_scale;
	if (dashStyle == 1)
		context.setLineDash([4 * scale, scale]);
	else if (dashStyle == 2)
		context.setLineDash([scale, scale]);
	else if (dashStyle == 3)
		context.setLineDash([4 * scale, scale, scale, scale]);
	else if (dashStyle == 4)
		context.setLineDash([4 * scale, scale, scale, scale, scale, scale]);
	else
		context.setLineDash([]);
