Normal Topic What is the proper way to destroy a VirtualKeyboard? (Read 3939 times)
MFusion Swing KBoard
May 1st, 2019 at 7:53pm
Disposing of a parent component containing a VirtualKeyboard places the VirtualKeyboard into a strange state where it rapidly and repeatedly generates infinite keystrokes.  Setting the parent component to invisible appears to be a workaround, but I prefer to destroy the VirtualKeyboard.
Re: What is the proper way to destroy a VirtualKeyboard?
Reply #1 - May 2nd, 2019 at 11:56am
Are you disposing the parent frame in response to keyboard's keyPressed event? Then the keyboard might not receive a mouseReleased message from whose handler it stops the auto-repeat timer.
Reply #2 - May 2nd, 2019 at 3:08pm
Good comment - thank you.  So, how best to dispose of the keyboard?
Reply #3 - May 3rd, 2019 at 8:01am
If that's the case, we'll add some method to stop the auto-repeat timer. Meanwhile try waiting for mouseReleased event before disposing the parent frame, the keyboard should stop it automatically at that point.
Reply #4 - May 3rd, 2019 at 8:14am
This build adds keyboard's own dispose method -
https://mindfusion.eu/_temp/JKeyboard.zip
Try calling it along with the frame's one.
Reply #5 - May 3rd, 2019 at 10:53am
Thanks! I tried it and it works!!
« Last Edit: May 3rd, 2019 at 12:58pm by MFusion Swing KBoard »
