Normal Topic update to 3.5.4 problem (Read 1829 times)
PDM.
Senior Member
May 2nd, 2019 at 7:23am
Severity      Code      Description      Project      File      Line      Suppression State
Error            Unknown build error, 'The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) Line 1601 Position 18.'            C:\xxxxxxxxxxxxxx\window6\Window6.xaml      1601
some idea?
« Last Edit: May 2nd, 2019 at 8:35am by PDM. »
Re: update to 3.5.4 problem
Reply #1 - May 2nd, 2019 at 11:59am
Verify all your project's mindfusion.* references have the 'use specific version' property shown disabled in VS property window.
PDM.
Senior Member
Reply #2 - May 3rd, 2019 at 5:17am
All mindfusion libs, already setup to false, anyway I recheck and can confirm are setup to false.
Error            Unknown build error, 'The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) Line 1600 Position 18.'      Modular      C:\xxxxxxxxxxx\window6\Window6.xaml      1600
When i double click on the error the ine 1600 position 8 is:
  <local:MyDiagram x:Name="form"
The app is targeted to netframewok 7.2
I dont know how fix this  Embarrassed
PDM.
Senior Member
Reply #3 - May 3rd, 2019 at 5:43am
Wow! really strange, this never happen before.
I solve finally doing this
C:\Windows\Microsoft.NET
Delete all mindfusion content I found inside in GAC
Then open Visual Studio, just remove all references, added again.
Clean, rebuild, then all back to normal!!
Solved.  Cheesy
PDM.
Senior Member
Reply #4 - May 3rd, 2019 at 5:48am
Im crazy or I note compile more faster, the app run more faster?
I check correctly and my update is form 3.3 to 3.5.4
I see all run more smoth now, more faster. Shocked
