Normal Topic same canvas for loading and creating the diagram (Read 3107 times)
liza
May 14th, 2019 at 3:57am
This time from where I referenced the code, @Html.DiagramView is used for creating diagram now my question is can we use the same for loading our diagram from database also?. This time I am using other canvas for loading diagram from the database.
AIM
Lyubo
MindFusion team
Re: same canvas for loading and creating the diagram
Reply #1 - May 14th, 2019 at 6:15am
What do you mean by "other canvas"? Do you mean on the server-side? You can store your diagram data as a string or JSON then use either Diagram.LoadFromString or DiagramView.LoadFromJson to load it from the database.
DiagramView view = DiagramView.FromRequest("diagramView1", Request);
view.Diagram.LoadFromString(myDatabaseStringValue);
ViewBag.DiagramView = view;
Code (HTML)
<div style="position: absolute; left: 0px; top: 0px; bottom: 0px; right: 0px">
    @Html.DiagramView(((DiagramView)ViewBag.DiagramView), new { style = "width:100%;height:100%;" })
</div>
Check the Network and Flowchart samples, provided with the MvcDiagram package. They illustrate different ways to save/load the diagram from file.
Lyubo
liza
Reply #2 - May 14th, 2019 at 8:06am
Can I open my diagram in edited form. and after updating diagram(updating text, deleting node, deleting link, adding other link mong other node), it should get saved and again load eith the updated data.
AIM
liza
Reply #3 - May 14th, 2019 at 11:04am
Lyubo wrote on May 14th, 2019 at 6:15am:
Code (HTML)
</div>
Lyubo
please elaborate it more. I am not clear with this.
AIM
Lyubo
MindFusion team
Reply #4 - May 14th, 2019 at 11:24am
This code shows how you can load the diagram from string (for example retrieved from database) on the server-side and associate the view with the canvas on the client-side.
For more code examples like this you can refer to the online documentation and tutorials here: https://www.mindfusion.eu/onlinehelp/mvcdiagram/index.htm?CC_Tutorial_1__Getting... and sample applications provided with the MvcDiagram package.
Lyubo
