Normal Topic set node as rootnode (Read 3155 times)
liza
May 14th, 2019 at 5:52am
Please anyone help me in the issue:I want to set a node as a root node at level 0 , so that other then that all the created nodes will display on its next level. How can I achieve it.
AIM
Lyubo
MindFusion team
Re: set node as rootnode
Reply #1 - May 14th, 2019 at 9:09am
As suggested in this post: https://mindfusion.eu/Forum/YaBB.pl?num=1557728236/3#3, you can set the AllowIncomingLinks property to false and this will restrict the root node to only permit outgoing links, so when using Tree or Layered layout, the root node will be always at the first level.
Lyubo
liza
Reply #2 - May 15th, 2019 at 11:09am
It is not working, still it in on the same level of other node
AIM
Lyubo
MindFusion team
Reply #3 - May 15th, 2019 at 12:26pm
Him
Try setting the MultipleGraphPlacement property of the layout to Vertical, and it should orient the graph so that the root node is at the top.
Lyubo
liza
Reply #4 - May 16th, 2019 at 4:30am
multipleGraphPlacement is integer property. And by default it is set to 1, what should I set into it to get it vertical.
Actually I made a default node with the following code and I want to set it at the top :
var root = diagram.getFactory().createShapeNode(bounds);
root.setShape("Ellipse");
root.setBrush("yellow");
root.setText(workflowname);
root.setLocked(true); // prevent drawing links
var rootNode = root;
and with the following code I am setting it as the root node.
var layout = new LayeredLayout();
  layout.Root = rootNode;
layout.nodeDistance = 15;
layout.layerDistance = 15;
diagram.arrange(layout);
and now U want to get it at the top.
In the below diagram yellow node is my default and want to have it at the top of "Step" Please help
AIM
liza
Reply #5 - May 16th, 2019 at 4:58am
I set it to 0 and it worked. Now I want to set the root node to the center. Please help me to achieve this.
AIM
Lyubo
MindFusion team
Reply #6 - May 17th, 2019 at 8:38am
You can set the root node's position by calling its setBounds method on the client side. To get the diagram view's bounds, call its getBounds method, or getContentBounds, if you want to get only the bounding rectangle of all items present.
Lyubo
