Normal Topic Cancel the containerChildAdding event (Read 4111 times)
Shafi
Jul 5th, 2019 at 3:14pm
Can you please let me know how to stop the containerChildAdding event? I have tried args.cancelDrag() and args.setCancel(true) but it does not really cancel this event.
Also I have noticed that the containerChildAdding is called even if the node is moved inside the same parent container. How to stop this behavior?
Lyubo
MindFusion team
Re: Cancel the containerChildAdding event
Reply #1 - Jul 8th, 2019 at 5:14am
To cancel the operation from a containerChildAdding event handler, you need to use:
Code (Javascript)
args.setCancel(true);
To distinguish from a containerChildAdding handler if a node is already a child of the particular container use:
Code (Javascript)
var node = args.getNode();
var container = args.getContainer();
var isAlreadyChild = container === node.getContainer();
To forbid all child adding operations for a container use:
Code (Javascript)
container.setAllowAddChildren(false);
Lyubo
Shafi
Reply #2 - Jul 8th, 2019 at 3:03pm
Thanks for the suggestions. Could you also please explain whats the difference between cancelDrag and setCancel(true)?
Reply #3 - Jul 10th, 2019 at 7:03am
cancelDrag can be called from nodeCreating / nodeModifying event handlers to immediately stop the drag operation, instead of only changing the mouse cursor. It probably won't have any effect if called from containerChildAdding.
Shafi
Reply #4 - Jul 11th, 2019 at 1:57pm
I have tried your suggestion for checking isAlreadyChild, but it does not exactly fit my scenario.
Please refer to the screenshot attached.
I want to cancel the adding of child2 to child1, but both the nodes are child of "Parent" node.
The containerChildAdding is called for "child1" as ContainerNode as well as "Parent" as ContainerNode . So the isAlreadyChild fails when the args.getContainer() is "Parent" and also the last event it checks for "Parent" node, but it gets added in the "Child1". I have attached the logs for this scenario.
Reply #5 - Jul 16th, 2019 at 8:02am
Get this new build -
https://mindfusion.eu/_beta/jsdiag334.zip
and you should be able to handle that like this -
function onContainerChildAdding(sender, args)
	var ctr = args.getContainer();
	// prevent third level nested containers
	// do not allow dropping container into an already nested container
	if (args.getNode().children && ctr.getContainer())
		args.setHandled(true);
	// do not allow dropping parent of nested containers into a container
	if (args.getNode().children)
		for (var child of args.getNode().children)
			if (child.children)
				break;
If you set args.Handled, it stops propagation of the event to parent containers and the dropped node resets to original position, otherwise it could still be accepted by another container in the hierarchy.
Shafi
Reply #6 - Aug 5th, 2019 at 8:54am
Thanks for the solution. Could you please add it to the  d.ts file ?
Reply #7 - Aug 5th, 2019 at 12:56pm
Please find it attached.
jsdiag_d_003.zip (Attachment deleted)
