Normal Topic Performance issue while loading more thank 100 node (Read 1948 times)
Suman
Jul 10th, 2019 at 9:53am
Trying to load 137 nodes with 170 edges is taking a long time to load the diagram.
Re: Performance issue while loading more thank 100 node
Reply #1 - Jul 10th, 2019 at 6:33pm
$(document).ready(function ()
	var start = Date.now();
	var diagram = Diagram.create($("#diagram")[0]);
	for (var i = 0; i < 137; i++)
		diagram.getFactory().createShapeNode((i % 8) * 50, Math.floor(i / 8) * 50, 30, 30);
	for (var i = 0; i < 170; i++)
		diagram.getFactory().createDiagramLink(
			diagram.nodes[i % 136], diagram.nodes[(i + 1) % 136]);
	diagram.fromJson(
		diagram.toJson());
	console.log(Date.now() - start + " milliseconds");
takes 553 milliseconds for me.
Suman
Reply #2 - Jul 11th, 2019 at 5:40am
Hi Slavcho,
Thanks for the reply. Can you please share your email id. So that I can share my json over email.
Reply #3 - Jul 11th, 2019 at 9:38am
You could attach it to a private message, or email to support inbox at our domain.
Reply #4 - Jul 12th, 2019 at 7:55am
This JSON contains some custom CINode type. If I replace its instances with MindFusion.Diagramming.ShapeNode, the diagram loads immediately, so you should debug the delay in the CINode code.
