Normal Topic Support for Touch Screen (Read 1319 times)
alukes
Jul 14th, 2019 at 4:45am
I see that I can do a single touch on a touch screen (smart phone) and it acts like a click.
Is it possible to detect a double touch so it acts like a double click?
How about a right click equivalent for a touch screen?
Also is dragging from a node list to the main canvas supported?
If so how?
alukes
Re: Support for Touch Screen
Reply #1 - Jul 18th, 2019 at 3:18pm
If touch screen isn't supported, that is OK. I need to let others on my team know either way so that if touch screen isn't supported, I will tell them not to work on touch screen support for the rest of the project of which flow diagramming is a part.
Reply #2 - Jul 19th, 2019 at 6:01am
Sorry, haven't noticed your post. Touch is supported since this release -
https://mindfusion.eu/Forum/YaBB.pl?num=1328004608/1#1
Otherwise the browser would scroll instead of letting you draw shapes. The diagram now handles single-finger touch for drawing and selection, and two-finger touch for scrolling and zooming. Double tap works as double click in my test, opening the node text editor.
We'll try to add long-press events for upcoming release, which you could handle instead of right-clicks.
NodeListView should work with touch, but try first calling its setTargetView method.
