Hot Topic (More than 10 Replies) Tooltip Not Closing & Tooltip Customizing ! (Read 5350 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jul 19th, 2019 at 8:44am
I've a tab in my application and diagram is shown in that tab.
I've created a composite node and setting tool tip like this,
compNode.setTooltip("Hi");
When I move the mouse over the node, the toop tip is displayed.
At that time, on right click on the node, I displays a context menu and on clicking on that creates a new tab and select that tab.
In the second tab also the same tool tip is displayed and it is not closed.
To close that, I need to come back to first tab and move the mouse.
May I know why this happens?
Kannan
« Last Edit: Jul 30th, 2019 at 12:42pm by Kannan Thirumal »
Online
Re: Tooltip Not Closing !
Reply #1 - Jul 19th, 2019 at 4:00pm
The tooltip div is not a child of the diagram's div, so hiding the latter (or whatever your tab control does with it, like changing Z orders) won't remove the tooltip. Try calling diagram.clearTooltip() method to clear it explicitly when changing tabs.
Kannan Thirumal
Senior Member
Reply #2 - Jul 22nd, 2019 at 7:18am
Thank you Slavcho, with that, we can clear the diagram tooltip on switching tabs or showing context menu. It works !
Also I saw hidden property in the tooltip element. Is this works?
        var tooltip = document.querySelector("div#diagram_tooltip");
        tooltip.hidden = true;
Kannan
Lyubo
MindFusion team
Reply #3 - Jul 22nd, 2019 at 10:16am
Calling diagram.clearTooltip() is the recommended way to handle this case. Modifying the DOM element of the tooltip for that purpose may have undesired side-effects.
Lyubo
Kannan Thirumal
Senior Member
Reply #4 - Jul 30th, 2019 at 8:04am
     Is there any way to customize the tooltip like changing the background color, font, size etc
Kannan
Lyubo
MindFusion team
Reply #5 - Jul 30th, 2019 at 10:06am
We will add the ability to style tooltips via CSS in the upcoming release, but in the meantime you can override the diagram.onTooltip method and customize the tooltip there. For example:
Code (Javascript)
var originalOnTooltip = MindFusion.Diagramming.Diagram.prototype.onTooltip;
MindFusion.Diagramming.Diagram.prototype.onTooltip = function()
	originalOnTooltip.apply(this, []);
	if (this.tooltipDiv)
		this.tooltipDiv.style.background = "#a0a0a0";
		var tooltipText = document.createElement("span");
		tooltipText.style.font = "bold 12px Verdana, serif";
		tooltipText.style.color = "white";
		tooltipText.style.margin = "5px"
		tooltipText.innerHTML = this.tooltipDiv.innerHTML;
		this.tooltipDiv.innerHTML = null;
		this.tooltipDiv.appendChild(tooltipText);
You can also apply CSS style via the tooltip's div id (the default id is the diagram canvas element name + "_tooltip"), but you won't really be able to style the text that way, only the div.
Lyubo
Kannan Thirumal
Senior Member
Reply #6 - Jul 30th, 2019 at 12:41pm
Thank you Lyubo. It works ! When the css way of customizing is released, please let me know.
Lyubo
MindFusion team
Re: Tooltip Not Closing & Tooltip Customizing !
Reply #7 - Jul 31st, 2019 at 11:05am
Support for CSS styling of the tooltips is added in this new beta build: https://mindfusion.eu/_beta/jsdiag334.zip.
Code (CSS)
.mf_diagram_tooltip
	background: #a0a0a0 !important;
.mf_diagram_tooltip span
	font: bold 12px Verdana, serif;
	color: white;
	margin: 5px;
.mf_nodeList_tooltip
.mf_nodeList_tooltip span
	color: white;
	margin: 5px;
Lyubo
Kannan Thirumal
Senior Member
Reply #8 - Aug 1st, 2019 at 7:09am
Thank you Lyubo  Smiley
Kannan Thirumal
Senior Member
Reply #9 - Apr 3rd, 2020 at 12:35pm
When the node is in the right side of the diagram, then the tooltip is shown in multiple lines (as shown in image-1)
So, I set style to nowrap like below,
tooltipText.style.whiteSpace = "nowrap";
Now the tooltip is shown in single line but it is shown out of diagram and also horizontal scroll bar (chrome browser) shown (as shown in image-2)
May I know how to show the tooltip inside the diagram without scroll bar?
Kannan
Kannan Thirumal
Senior Member
Reply #10 - Aug 24th, 2021 at 11:33am
This tool tip is working fine till the version 3.5.2. From 3.5.3, tool tip is not working. Also for the below code, this.tooltipDiv is undefined. Even after commenting the below code also, tool is not showing.
May I know any changes happened in the recent builds? I couldn't see anything related to tis in the release notes: https://www.npmjs.com/package/diagram-library
Kannan
Lyubo wrote on Jul 30th, 2019 at 10:06am:
Code (Javascript)
Lyubo
Online
Reply #11 - Aug 24th, 2021 at 7:16pm
We can't find any changes related to tooltips in git commits, and copying that code to the anchor points example seems to work correctly with v3.5.3. Let us know what we should change in Anchors.js code to reproduce.
decb1.setTooltip("check 1");
decb1.setAnchorPattern(decision1In3Out);
var decision2In2Out = MindFusion.Diagramming.AnchorPattern.fromId("Decision2In2Out");
decb2 = diagram.getFactory().createShapeNode(new Rect(70, 30, 30, 20));
decb2.setShape("Decision");
decb2.setText("check 2");
decb2.setTooltip("check 2");
decb2.setAnchorPattern(decision2In2Out);
		tooltipText.style.color = "red";
Kannan Thirumal
Senior Member
Reply #12 - Aug 25th, 2021 at 6:09am
Looks like it is working for shape node and not for composite node. Could you please check in my earlier sample code?
https://drive.google.com/file/d/17q1JNEzEi2tqHA2c1PhtD1aGUomBlDyB/view?usp=shari
ng
Kannan
Online
Reply #13 - Aug 25th, 2021 at 8:05am
That seems coming from AnchorPoint.tooltip property in v3.5.4 and a very large anchor point you set for your nodes. Use this as work-around for time being:
   var originalAnchorPointGetToolTip = MindFusion.Diagramming.AnchorPoint.prototype.getToolTip;
    MindFusion.Diagramming.AnchorPoint.prototype.getToolTip = function()
      var tooltip = originalAnchorPointGetToolTip.call(this);
      if (tooltip == null)
        return "";
      return tooltip;
