Normal Topic Link ZOrder not respected on node selection (Read 2230 times)
jcaron
Jul 23rd, 2019 at 7:15pm
When a node is selected in the DiagramView, all the links of the node appear on top of the nodes (the selected node and the nodes at the other end of the links). As my anchor point is in the middle, this hides the text of the nodes. I tried setting the ZBottom for all my links, but without success. Am I doing something wrong?
Thanks!
Re: Link ZOrder not respected on node selection
Reply #1 - Jul 24th, 2019 at 6:26am
The diagram does that on purpose to better show connections to the active node. It usually wouldn't be a problem with links aligning to node borders, but I can see it's not looking nice if connecting to the node center. Setting SelectionOnTop = false should prevent that.
jcaron
Reply #2 - Jul 24th, 2019 at 11:47am
Thanks for the quick answer, it solved my problem.
Jean
