Normal Topic FlowChartX V4.9.5 released! (Read 2781 times)
Jul 29th, 2019 at 12:31pm
We have released version 4.9.5 of FlowChartX. It contains the following new features and improvements:
Selection improvements
  • Pen style and color of the selection lasso can be customized via LassoStyle, LassoWidth and LassoColor properties of SelectionOptions.
  • Holding Shift when drawing selection lasso will extend multiple selection, without deselecting previously selected items.
  • Dragging the pointed item when ModificationStart mode is set to auto-handles and holding down Ctrl will add the item to multiple selection.
  • Set the fDisableSelectionDirtyFlag bit of EventFlags to prevent setting Dirty when selection changes.
Flowchart size and scrolling
  • AutoSizeDirections property of FlowChart specifies in what directions auto-sizing should be allowed.
  • AutoScrollType property of FlowChart toggles between two auto-scroll modes.
  • ncKeepInsideDiagram constraint can now be assigned to a node's Constraints.
  • Type-specific BoxModified, TableModified and ArrowModified events are now raised in addition to the general ObjectModified.
  • SetTextPadding method added to the Box class.
  • The TextFits method determines whether text fits inside current size of a box.
Installer for the latest version can be downloaded here, or from the clients area on our site.
https://www.mindfusion.eu/FCXdemoPro.zip
