Normal Topic The link is not as expected (Read 2752 times)
Ngo Duc Quang
Aug 5th, 2019 at 8:28am
Hi, I'm having some minor problems as follows: The link is not as expected.
Picture 1: The link I want is correct.
Picture 2: This is the chart image I am processing.
Do you have any solution?
Thank you!
Re: The link is not as expected
Reply #1 - Aug 5th, 2019 at 9:56am
Is this after moving selection or running layout class? Some layout classes ignore links that form cycles in the graph, you might try calling link.route() or diagram.routeAllLinks() after applying them.
Ngo Duc Quang
Reply #2 - Aug 5th, 2019 at 10:16am
Thank you very much  Grin Grin
