Normal Topic What is the new default layout mind fusion used for diagram creation? (Read 4225 times)
Aniket
Aug 22nd, 2019 at 8:01am
What is the default layout mind fusion uses while loading diagram?
Thanks.
Re: What is the new default layout mind fusion used for diagram creation?
Reply #1 - Aug 22nd, 2019 at 8:44am
If you mean after calling save/load methods, there isn't any layout applied automatically. The load method restores the positions items had when saving.
Aniket
Reply #2 - Aug 22nd, 2019 at 9:12am
1. I am using diagram.getFactory().createShapeNode() method for creating nodes and diagram.getFactory().createDiagramLink() for creating link. When diagram loads the nodes are placed in 2D Table. I want to know if there is any name for this 2D Table layout format or diagram is placing nodes only on screen resolutions and bounds given while creating node.
2. While avoiding node overlap in spring layout I am using SpringLayoutTraits. While using this I am getting is SpringLayoutTraits not defined error in javascript. Is there anything that I can do to avoid this.
Thanks in advance.
Reply #3 - Aug 22nd, 2019 at 12:41pm
What platform are you using?
1. There isn't any built-in tabular layout. I guess you will get one if you have based your code on some of the examples that show a grid of shapes (like StockShapes, PostBack sample projects).
2. The JavaScript library is still a smaller subset of our .NET code and it does not contain SpringLayoutTraits at this time.
Aniket
Reply #4 - Aug 22nd, 2019 at 12:59pm
Thanks for the response.
Is there a way to avoid node overlapping in spring layout using javascript library?
Thanks.
Reply #5 - Aug 22nd, 2019 at 1:22pm
I guess try larger nodeDistance and iterations property values (default ones being 30 and 300). This is kind of physical simulation and does not guarantee there won't be overlapped nodes - repulsion forces between nodes could be minimized if they are connected with too many links to surrounding nodes that pull them to the interior. Otherwise try a different layout class such as LayeredLayout.
Reply #6 - Aug 22nd, 2019 at 2:19pm
This Topic was moved here from Discussion [move by] Forum Admin.
