Normal Topic Shadow Color for Composite Node ! (Read 1760 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Aug 28th, 2019 at 1:41pm
I've defined a composite node like below and trying to set shadow color. But it doesn't seems working for composite node. May I know why? Working fine for ShapeNode.
private createNodes() {
this.DiagramNode = CompositeNode.classFromTemplate("DiagramNode",
component: "GridPanel",
rowDefinitions: ["*"],
columnDefinitions: ["22", "*"],
children:
component: "Rect",
pen: "black",
brush: "white",
columnSpan: 2,
component: "Image",
autoProperty: true,
margin: "1",
imageAlign: "Fit"
component: "StackPanel",
orientation: "Vertical",
gridColumn: 1,
margin: "1",
verticalAlignment: "Near",
children:
component: "Text",
autoProperty: true,
text: "",
font: "Arial bold 20",
padding: "10,0,1,0"
component: "Text",
autoProperty: true,
text: "full name",
pen: "blue",
font: "Arial 20",
padding: "10,10,10,0"
var node = new this.DiagramNode();
node.setBounds(new Rect(100, 200, 200, 50));
node.setFullName("Composite node")
node.setTooltip("Composite node");
(node as any).setShadowColor("blue");
this.diagram.addItem(node);
var node1 = this.diagram.getFactory().createShapeNode(new Rect(500, 200, 150, 50));
node1.setText("Shape node");
node1.setFont(new Font("Arial", 20, false, false, false));
node1.setBrush("white");
node1.setShadowColor("blue");
node1.setTooltip("Shape node");
this.diagram.addItem(node1);
Kannan
Re: Shadow Color for Composite Node !
Reply #1 - Aug 28th, 2019 at 7:36pm
Apparently CompositeNode does not apply shadows to any of the components automatically. You could show one for the background rectangle like this -
node.setShadowColor("blue");
node.getComponent("Background").shadow = node.createShadow();
Kannan Thirumal
Senior Member
Reply #2 - Aug 29th, 2019 at 3:41am
It works  Smiley Thank you Slavcho  Cheesy
