Normal Topic Tool Box (Read 3589 times)
liza
Tool Box
Sep 3rd, 2019 at 8:01am
How can I show toolbox on the left side of the canvas, to select the icons/symbol using drag and drop. Please let me know
AIM
Re: Tool Box
Reply #1 - Sep 3rd, 2019 at 9:37am
Add a NodeListView instance on the left of DiagramView.
liza
Re: Tool Box
Reply #2 - Sep 3rd, 2019 at 9:38am
Please elaborate more, how to use it. I am drawing client side.
AIM
Re: Tool Box
Reply #3 - Sep 3rd, 2019 at 11:11am
You can see how to set it up in Controls and Tutorial3 sample projects. If you need to add nodes from client side -
@Html.NodeListView(
((NodeListView)ViewBag.NodeListView).ControlLoadedScript("nodeListLoad")
, new { style = "width:200px; height:500px;" })
<script type="text/javascript">
    function nodeListLoad(sender)
        var node = new MindFusion.Diagramming.ShapeNode();
        node.setShape("Actor");
        sender.addNode(node, "node text");
</script>
liza
Re: Tool Box
Reply #4 - Sep 3rd, 2019 at 11:23am
Thanks, but it is giving null reference error, can you please tell me that what type of content will be in viewbag?
AIM
Re: Tool Box
Reply #5 - Sep 3rd, 2019 at 11:36am
The ViewBag field should be set to a NodeListView instance, as the sample projects cited above show, e.g. -
var nodeListView = new NodeListView("nodeListView");
// add some nodes to the NodeListView
string[] shapes = new string[] { "Actor", "RoundRect", "Triangle", "Decision" };
for (var i = 0; i < shapes.Length; ++i)
      var node = new ShapeNode();
      node.Text = shapes[i];
      node.Shape = Shape.FromId(shapes[i]);
      nodeListView.AddNode(node, shapes[i]);
ViewBag.NodeListView = nodeListView;
liza
Re: Tool Box
Reply #6 - Sep 3rd, 2019 at 12:02pm
Thanks, it is working.
AIM
liza
Re: Tool Box
Reply #7 - Sep 4th, 2019 at 3:53am
I want to have arrow, by selecting it and put it with a node then the two nodes should be linked together. How can I do this?
AIM
Re: Tool Box
Reply #8 - Sep 5th, 2019 at 6:45am
NodeListView cannot contain links, but you could add a node representing a connector and replace it with a link when dropped. You can find this demonstrated for our WPF library here -
https://mindfusion.eu/blog/create-diagram-connectors-using-drag-and-drop/
Same approach should work for ASP.NET MVC / JavaScript too.
