Normal Topic set the link text (Read 1442 times)
liza
set the link text
Sep 4th, 2019 at 11:12am
HI,
I want to show link text between the link without overlapping with link line if it is not empty. and if there is no link text then it should connect nodes normally without breakage of line.
Your help will be appreciated.
AIM
Re: set the link text
Reply #1 - Sep 5th, 2019 at 6:40am
Try the different LinkTextStyle values to see if some will work for you. Otherwise add a LinkLabel and enable its AutoArrange property - it should select a position near link's path but avoiding its segments then. You could as well set custom positions for LinkLabels.
