Normal Topic node gets out of canvas box (Read 4114 times)
liza
Sep 5th, 2019 at 5:50am
Sometimes my node became invisible because it gets out of the view. How I can set so that my diagram will alsowas be shown in the view. Please help.
AIM
Re: node gets out of canvas box
Reply #1 - Sep 5th, 2019 at 6:36am
You could call diagram.resizeToFitItems() after adding and arranging nodes to make diagram.Bounds large enough to contain them. If you enable Diagram.AutoResize, it should grow automatically to contain nodes drawn interactively by users.
liza
Reply #2 - Sep 5th, 2019 at 6:56am
I tried this but it is creating a very small rectangle in which only my one node is visible not whole diagram. and When I use Diagram.AutoResize() it is saying is not a function . What should I do please help.
AIM
Reply #3 - Sep 5th, 2019 at 7:01am
It's a property you could set on server side, or otherwise call Diagram.setAutoResize on client side. If you need the diagram to only grow, you could check if diagram.getBounds() contains diagram.getContentBounds(), and if it doesn't do a union of the two rectangles and assign it back to Bounds.
liza
Reply #4 - Sep 16th, 2019 at 6:32am
can you please elaborate it how I can I use union and assign to bounds.
AIM
Reply #5 - Sep 16th, 2019 at 8:57am
like this -
function growToFitItems(diagram)
	var margin = 10;
	var contentRect = diagram.getContentBounds();
	var diagRect = diagram.getBounds();
	if (contentRect.bottom() > diagRect.bottom() ||
		contentRect.right() > diagRect.right())
		diagram.setBounds(
			diagRect.union(contentRect.inflate(margin)));
liza
Reply #6 - Sep 17th, 2019 at 5:28am
Thankyou its done, my height got increased but width by changing layout was again out of focus, so I set margin to 20 and it is fine now.
AIM
