Normal Topic Show four points on node to link (Read 955 times)
liza
Sep 6th, 2019 at 6:06am
Hi, In many examples I have seen that On hovering node, there are different color point visible(normally four) around that node and which is used for linking. No other than that four points are there to start linking. I want same, how can I achieve it.
AIM
Re: Show four points on node to link
Reply #1 - Sep 7th, 2019 at 6:34am
That's done using AnchorPattern and AnchorPoint objects. Check the source code of AnchorPoints example installed with the library.
liza
Reply #2 - Sep 9th, 2019 at 6:04am
Thanks it is done
AIM
