Normal Topic Multiple selection does not respect grid anchors (Read 2219 times)
Luca Corsini
Sep 30th, 2019 at 1:52pm
Hi. I have been trying the diagrams for quite a bit now and the product works well for all of my needs.
Anyway, I have a problem that I can't fix. When I select a single item and drag it, the item moves inside the grid (I have set setShowGrid to true) correctly, following the anchors, but when I select multiple items (nodes and links), these are moving freely inside the diagram without following the anchors.
Could you suggest a solution to this problem? thank you.
Re: Multiple selection does not respect grid anchors
Reply #1 - Oct 1st, 2019 at 5:10am
I wasn't able to reproduce at first, and found AllowMultipleResize being enabled in my test project leads to aligning correctly, so try this as a solution if you don't mind the resizing -
diagram.setAllowMultipleResize(true);
With it disabled, it seems there's some error accumulating and showing after you move same selection a few times? Our developer will check that.
« Last Edit: Oct 1st, 2019 at 6:37am by Slavcho »
Luca Corsini
Reply #2 - Oct 1st, 2019 at 6:19am
Great! With this property it works! I resized and moved a lot of elements multiple times and everything works fine, thank you (maybe i suggest you to add this method in the documentation if there isn't, i couldn't find it).
I have one last thing to settle: If i move an element to the bottom edges of the canvas to resize it, when I reload the diagram everything is fine. By the way, if I do the same thing to the top edges, when I reload the diagram it looks like the diagram moves everything to the top corner and some nodes superimpose others. I will attach two screenshots.
« Last Edit: Oct 1st, 2019 at 9:27am by Luca Corsini »
Reply #3 - Oct 1st, 2019 at 10:33am
What do you mean by reloading the diagram? Loading from a file, or regenerating it from data and running some layout code?
Reply #4 - Oct 2nd, 2019 at 4:54am
This should fix alignment when selection resizing disabled -
https://mindfusion.eu/_beta/jsdiag_alignsel.zip
If applying layout code, please post it.
