Normal Topic How Get Data From Database (Read 3103 times)
Surhar
Oct 8th, 2019 at 10:44am
i want to get data from database from can sombody help me...
each node must be comes from database..
Re: How Get Data From Database
Reply #1 - Oct 8th, 2019 at 7:06pm
Create a web service that returns your DB records in JSON format, and then create nodes from the service' response as shown in first couple of tutorials here -
https://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?CC_Tutorials_13.htm
Surhar
Reply #2 - Oct 9th, 2019 at 6:51am
can u explain in new to here i have no basic knowladge can put code her to how to get node from database
Reply #3 - Oct 9th, 2019 at 8:39am
That all depends on what programming language your server application runs on and your database schema, and generally you should acquire some basic knowledge in database programming if you'll be doing anything with databases.
