Normal Topic changing adding node pattern (Read 2068 times)
liza
Nov 7th, 2019 at 9:34am
This time the node are getting added to the left side(left-down) of the parent node, I want to add the new node right doen of the parent node, is it possible to handle?
AIM
Re: changing adding node pattern
Reply #1 - Nov 8th, 2019 at 7:08am
Do you mean when calling diagram.arrange? What layout settings are you using?
liza
Reply #2 - Nov 13th, 2019 at 9:39am
I am using FlowchartLayout
AIM
Reply #3 - Nov 14th, 2019 at 7:31am
FlowchartLayout always arranges child nodes from left to right. You have some control over their order via parent node's OutgoingLinks list order.
