Normal Topic node create and text (Read 2908 times)
liza
Nov 13th, 2019 at 9:41am
Hi, I want to open the editor for the node just after creating the node, this time it is happening at the time of double click of node. Please help for this.
AIM
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Re: node create and text
Reply #1 - Nov 13th, 2019 at 9:49am
This may help you,
diagram.beginEdit(node, new Point(0, 0));
https://mindfusion.eu/Forum/YaBB.pl?num=1568953899
liza
Reply #2 - Nov 21st, 2019 at 5:54am
hi,
I wrote in this way, but it is not working
function onNodeCreated(s, e) {
    var hubId = $.connection.hub.id;
    e.node.id = hubId + s.getItems().length;
    var r = e.node.bounds;
    e.node.setBounds(new Rect(r.x, r.y, 18, 10));
    e.node.setAnchorPattern(anchorPattern);
    var model = {
        x: r.x,
        y: r.y,
        width: 18,
        height: 10
    diagramHub.server.nodeCreated(model);
    creatednodeidupdate = e.node.id;
    diagram.beginEdit(e.node.bounds, new Point(0, 0));
AIM
Reply #3 - Nov 21st, 2019 at 6:59am
It expects node reference as argument, and not node's bounds. Other than that, the browser's debug window will give you more information why it's not working, like diagram variable being undefined, or Point shortcut not set (to MindFusion.Drawing.Point).
liza
Reply #4 - Nov 26th, 2019 at 9:44am
Okay,
But now I am getting getActiveItem as null in nodecreated event. please help
AIM
Reply #5 - Nov 26th, 2019 at 1:56pm
getActiveItem will return null when there are no selected nodes. You have access to the newly create node via the e.node reference, already used in script above.
liza
Reply #6 - Dec 2nd, 2019 at 4:06am
you mean, I should use e.node.beginEdit(), but I tried that it is showing, "e.node.beginEdit()" is not a function. please clear if I am wrong.
AIM
liza
Reply #7 - Dec 2nd, 2019 at 4:08am
also I tried with e.node.beginedit , but nothing is happening.
AIM
Reply #8 - Dec 2nd, 2019 at 9:59am
I mean diagram.beginEdit(e.node) instead of diagram.beginEdit(diagram.getActiveItem());
liza
Reply #9 - Dec 6th, 2019 at 10:43am
Thank you it worked for me
AIM
