Normal Topic Use two diagram in same page diagram design Issue (Read 4857 times)
Pazhanivel
Nov 14th, 2019 at 6:40am
We are using Mind Fusion Diagram Version :6.3.2.26041
We try to display two diagrams in same page diagram not displayed with correct design. Node colors get overlap.
Re: Use two diagram in same page diagram design Issue
Reply #1 - Nov 14th, 2019 at 7:25am
Do you mean showing two DiagramViews on same page and second one renders incorrect colors? What ClientSideMode are you using? Please attach diagram XML files our developer could reproduce that with.
Pazhanivel
Reply #2 - Nov 14th, 2019 at 12:25pm
ClientSideMode : SvgImage
Diagram_XML_Files.zip (Attachment deleted)
Reply #3 - Nov 15th, 2019 at 9:15am
It's the same problem as https://stackoverflow.com/questions/16123721/how-to-use-local-defs-in-svg , we'll add some diagram-specific prefix to <defs> identifiers for upcoming release.
Reply #4 - Dec 12th, 2019 at 10:13am
This build adds svg defs prefix per diagram -
https://mindfusion.eu/_beta/netdiag622.zip
